[Qgis-developer] Copy of QGIS-NaturalEarth-Example.qgs, etc. -
Sample files for QGIS (Map) Server.
Noli Sicad
nsicad at gmail.com
Wed Jun 29 21:44:40 EDT 2011
Hi Alex,
Would be possible to get a copies of the 6 files i.e. data set for
Natural Earth**.qgis?
1. 10m_lakes.shp
2. 10m_land.shp
3. 10m_oceans.shp
4.********.shp
5.*******.shp
6. ************.tif
Probably you can zip this project and these layers and send me the URL
to download it.
Thanks.
Noli
On 6/30/11, Noli Sicad <nsicad at gmail.com> wrote:
> Hi Alex,
> The qgis projects are unusable without the data set.
> Any further instruction how get the date set synch with the project?
> If I download the natural earth data?
> Any possible download link with copy of the data set that comes with
> the qgis project e.g. NaturalEarth?
> I am trying to figure out the install_gisdata.sh. I am using the a Mac
> OS X. The script is bit tricky for Mac OS X since it design for linux.
> I see "POSTGRES_USER="user" ? It needs Postgresql?
> Thanks.
> Noli
> On 6/30/11, Alex Mandel <tech_dev at wildintellect.com> wrote:
>> Yup, they are all in the same svn folder. The other 2 examples are
>> dependent on I believe the Spearfish (might by NC) dataset from GRASS
>> and the Mapserver Itasca example that ships with mapserver.
>> We are including an OSM (.osm) file now (location changes yearly to
>> match FOSS4G), and a populated Postgis database (OSM and NaturalEarth).
>> It might be good to create a couple more examples using that data.
>> Thanks,
>> Alex
>> On 06/29/2011 05:54 PM, Noli Sicad wrote:
>>> OK.
>>> I got the other 2 qgis project examples.
>>> Thanks.
>>> Noli
>>>> Hi Alex,
>>>> Thanks for info and the link.
>>>>> http://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/app-data/qgis/QGIS-NaturalEarth-Example.qgs
>>>>> As for the data that comes directly from NaturalEarthData.com ,
>>>>> details
>>>>> are in the gisdata script:
>>>>> http://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/bin/install_gisdata.sh
>>>>> Note: there are 3 example qgis project files on the DVD currently.
>>>> Would it be possible to send me the link of other 2 qgis project files
>>>> example?
>>>> Thanks in advance.
>>>> Noli
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
