[Qgis-developer] Copy of QGIS-NaturalEarth-Example.qgs, etc. -
Sample files for QGIS (Map) Server.
Noli Sicad
nsicad at gmail.com
Wed Jun 29 21:49:37 EDT 2011
Forget about the request for the 6 files.
I am downloading the natural earth zip file. It says it has Qgis project in it.
http://www.naturalearthdata.com/downloads/
Thanks.
Noli
On 6/30/11, Noli Sicad <nsicad at gmail.com> wrote:
> Hi Alex,
> Would be possible to get a copies of the 6 files i.e. data set for
> Natural Earth**.qgis?
> 1. 10m_lakes.shp
> 2. 10m_land.shp
> 3. 10m_oceans.shp
> 4.********.shp
> 5.*******.shp
> 6. ************.tif
> Probably you can zip this project and these layers and send me the URL
> to download it.
> Thanks.
> Noli
>> Hi Alex,
>> The qgis projects are unusable without the data set.
>> Any further instruction how get the date set synch with the project?
>> If I download the natural earth data?
>> Any possible download link with copy of the data set that comes with
>> the qgis project e.g. NaturalEarth?
>> I am trying to figure out the install_gisdata.sh. I am using the a Mac
>> OS X. The script is bit tricky for Mac OS X since it design for linux.
>> I see "POSTGRES_USER="user" ? It needs Postgresql?
>> Thanks.
>> Noli
>> On 6/30/11, Alex Mandel <tech_dev at wildintellect.com> wrote:
>>> Yup, they are all in the same svn folder. The other 2 examples are
>>> dependent on I believe the Spearfish (might by NC) dataset from GRASS
>>> and the Mapserver Itasca example that ships with mapserver.
>>> We are including an OSM (.osm) file now (location changes yearly to
>>> match FOSS4G), and a populated Postgis database (OSM and NaturalEarth).
>>> It might be good to create a couple more examples using that data.
>>> Thanks,
>>> Alex
>>> On 06/29/2011 05:54 PM, Noli Sicad wrote:
>>>> OK.
>>>> I got the other 2 qgis project examples.
>>>> Thanks.
>>>> Noli
>>>>> Hi Alex,
>>>>> Thanks for info and the link.
>>>>>> http://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/app-data/qgis/QGIS-NaturalEarth-Example.qgs
>>>>>> As for the data that comes directly from NaturalEarthData.com ,
>>>>>> details
>>>>>> are in the gisdata script:
>>>>>> http://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/bin/install_gisdata.sh
>>>>>> Note: there are 3 example qgis project files on the DVD currently.
>>>>> Would it be possible to send me the link of other 2 qgis project files
>>>>> example?
>>>>> Thanks in advance.
>>>>> Noli
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
