[Qgis-developer] Copy of QGIS-NaturalEarth-Example.qgs, etc. - Sample files for QGIS (Map) Server.
Noli Sicad nsicad at gmail.com
Wed Jun 29 23:14:55 EDT 2011
Hi Alex,
The  http://www.naturalearthdata.com/downloads/ has all the data set
for the QGIS-NaturalEarth-Example.qgs.
Thanks for your help.
Regards, Noli
On 6/30/11, Noli Sicad <nsicad at gmail.com> wrote:
> Forget about the request for the 6 files.
> I am downloading the natural earth zip file. It says it has Qgis project in
> it.
> Thanks.
> Noli
>> Hi Alex,
>> Would be possible to get a copies of the 6 files i.e. data set for
>> Natural Earth**.qgis?
>> 1. 10m_lakes.shp
>> 2. 10m_land.shp
>> 3. 10m_oceans.shp
>> 4.********.shp
>> 5.*******.shp
>> 6. ************.tif
>> Probably you can zip this project and these layers and send me the URL
>> to download it.
>> Thanks.
>> Noli
>>> Hi Alex,
>>> The qgis projects are unusable without the data set.
>>> Any further instruction how get the date set synch with the project?
>>> If I download the natural earth data?
>>> Any possible download link with copy of the data set that comes with
>>> the qgis project e.g. NaturalEarth?
>>> I am trying to figure out the install_gisdata.sh. I am using the a Mac
>>> OS X. The script is bit tricky for Mac OS X since it design for linux.
>>> I see "POSTGRES_USER="user" ? It needs Postgresql?
>>> Thanks.
>>> Noli
>>> On 6/30/11, Alex Mandel <tech_dev at wildintellect.com> wrote:
>>>> Yup, they are all in the same svn folder. The other 2 examples are
>>>> dependent on I believe the Spearfish (might by NC) dataset from GRASS
>>>> and the Mapserver Itasca example that ships with mapserver.
>>>> We are including an OSM (.osm) file now (location changes yearly to
>>>> match FOSS4G), and a populated Postgis database (OSM and NaturalEarth).
>>>> It might be good to create a couple more examples using that data.
>>>> Thanks,
>>>> Alex
>>>> On 06/29/2011 05:54 PM, Noli Sicad wrote:
>>>>> OK.
>>>>> I got the other 2 qgis project examples.
>>>>> Thanks.
>>>>> Noli
>>>>>> Hi Alex,
>>>>>> Thanks for info and the link.
>>>>>>> http://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/app-data/qgis/QGIS-NaturalEarth-Example.qgs
>>>>>>> As for the data that comes directly from NaturalEarthData.com ,
>>>>>>> details
>>>>>>> are in the gisdata script:
>>>>>>> http://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/bin/install_gisdata.sh
>>>>>>> Note: there are 3 example qgis project files on the DVD currently.
>>>>>> Would it be possible to send me the link of other 2 qgis project
>>>>>> files
>>>>>> example?
>>>>>> Thanks in advance.
>>>>>> Noli
>>>>> _______________________________________________
>>>>> Qgis-developer mailing list
>>>>> Qgis-developer at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
