[Qgis-developer] macosx dialog issues
Carson Farmer
carson.farmer at gmail.com
Sat Mar 5 14:28:41 EST 2011
Hi John, I believ José had problems with:
- Geoprocessing tools available as Intersect two layers
- Data management tools as Export to projection
> The only problem I had was with Merge Shapefiles. If I tick the 'Select by layers in the folder', I cannot choose a folder in the dialog. The Ok button never becomes available when trying to select a folder. I can select a shapefile and the OK button is available. I might be misunderstanding what this option is intended to do. When turning it off, I can select a folder, but the tool crashed qgis. This was because my folder had mixed geometry types. See output below. I suppose this crash should be avoided somehow.
Hmm, ok I'll look into this one, thanks for the update.
> One random thought arose as I tested the tools. Why is the random select tool limited to 30 features?
What? It shouldn't be? Unless your layer only has 30 features?
Carson
Carson J. Q. Farmer
ISSP Doctoral Fellow
National Centre for Geocomputation
National University of Ireland, Maynooth,
http://www.carsonfarmer.com/
