[Qgis-developer] macosx dialog issues
Alexander Bruy alexander.bruy at gmail.com
Sun Mar 6 14:32:22 EST 2011
Hi Carson,
On Sun, 6 Mar 2011 18:02:28 +0000
Carson Farmer <carson.farmer at gmail.com> wrote:
> Hi Alexander,
> > 'Select by layers in the folder' checkbox allow you to select and
> > merge only some shapes not all available in folder. This can be usefull
> > when in folder many shapes with different geometries or when you need
> > only to merge only certain files.
> > When this checkbox turned off tool will work with whole folder, but note
> > that there is no geometry checks and output file will have same geometry
> > as first pocessed file. This behaviour is fixed in separate MergeShapes
> > plugin from GIS-Lab. I'll port it to fTools soon.
> That would be great, thanks for that :-)
Done in r15370.
Alexander Bruy
