[Qgis-developer] Icons disappearing when opening attribute table
Ivan Mincik
ivan.mincik at gmail.com
Tue Mar 8 16:25:23 EST 2011
Hi can anybody confirm following behavior ?
Would You please configure Your QGIS to "Open attribute table in dock
window", load this example data [1] and choose Layer -> Open Attribute
Table ?
In my case attribute table window is opened with blank buttons without
any icons. Icons will appear when moving mouse cursor over. The same I
can reproduce when resizing attribute table window. It seems that this
behavior occurs when some bigger shapefile with longer rendering time
(> 5 seconds) is loaded. When using attribute table in separate window
(not in dock window), icons are loaded correctly.
Software details:
OS: Debian Squeeze - Gnome, standard Clearlooks theme using Clearlooks buttons
QGIS: Trunk (I remember this behavior for versions in last few weeks)
If somebody can confirm, I will open ticket.
Thanks, Ivan
[1] - http://gista.sk/home/ivo/dl/qgis_demodata.tar.gz
