[Qgis-developer] Icons disappearing when opening attribute table
Werner Macho werner.macho at gmail.com
Tue Mar 8 16:51:58 EST 2011
hi Ivan!
Testet and confirmed.. no Icons appear - only when you move mouse cursor
over it ..
Tested latest trunk version r15392
so you can open a ticket..
regards
werner
On 03/08/11 22:25, Ivan Mincik wrote:
> Hi can anybody confirm following behavior ?
> Would You please configure Your QGIS to "Open attribute table in dock
> window", load this example data [1] and choose Layer -> Open Attribute
> Table ?
> In my case attribute table window is opened with blank buttons without
> any icons. Icons will appear when moving mouse cursor over. The same I
> can reproduce when resizing attribute table window. It seems that this
> behavior occurs when some bigger shapefile with longer rendering time
> (> 5 seconds) is loaded. When using attribute table in separate window
> (not in dock window), icons are loaded correctly.
> Software details:
> OS: Debian Squeeze - Gnome, standard Clearlooks theme using Clearlooks buttons
> QGIS: Trunk (I remember this behavior for versions in last few weeks)
> If somebody can confirm, I will open ticket.
> Thanks, Ivan
> [1] - http://gista.sk/home/ivo/dl/qgis_demodata.tar.gz
> Qgis-developer mailing list
