[Qgis-developer] Error opening ECW in latest trunk with OTF
raster support.
Nathan Woodrow
madmanwoo at gmail.com
Wed Mar 9 17:59:18 EST 2011
Pretty it knows where everything is; this is my qgis-dev.bat:
@echo off
SET OSGEO4W_ROOT=M:\TEMP\QGIS
call "%OSGEO4W_ROOT%"\bin\o4w_env.bat
call "%OSGEO4W_ROOT%"\bin\grass-env.bat
@echo off
path %PATH%;%GISBASE%\bin
set GDAL_DRIVER_PATH=”%OSGEO4W_ROOT%”\bin\gdalplugins\1.8
start "Quantum GIS" /B "%OSGEO4W_ROOT%"\apps\qgis-dev\bin\qgis.exe %*
Exactly the same as before the update.
- Nathan
On Thu, Mar 10, 2011 at 8:53 AM, Ramon Andinach <custard at westnet.com.au>wrote:
> On 10/03/2011, at 06:31 , Nathan Woodrow wrote:
> > Hi all,
> > I can't seem to open ecw files in the latest trunk build, I get a can
> "not open GDAL dataset {ecw name}" I was able to open them before the new
> raster OTF projection merge.
> > Running XP, QGIS r15395
> > Can anyone else confirm?
> You got an error message! Congratulations! You did better than me.
> (Are you sure it's not just that QGIS has forgotten where to look for the
> ECW libraries or GDAL plugins?)
> -ramon._______________________________________________
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110310/687d5863/attachment.html
