[Qgis-developer] Error opening ECW in latest trunk with OTF raster support.
Ramon Andinach custard at westnet.com.au
Wed Mar 9 18:23:59 EST 2011
That looks a lot like mine, which is loading ecw rasters so long as I don't turn OTF on.
Sorry, I'm not able to help more.
On 10/03/2011, at 06:59 , Nathan Woodrow wrote:
> Pretty it knows where everything is; this is my qgis-dev.bat:
> @echo off
> SET OSGEO4W_ROOT=M:\TEMP\QGIS
> call "%OSGEO4W_ROOT%"\bin\o4w_env.bat
> call "%OSGEO4W_ROOT%"\bin\grass-env.bat
> @echo off
> path %PATH%;%GISBASE%\bin
> set GDAL_DRIVER_PATH=”%OSGEO4W_ROOT%”\bin\gdalplugins\1.8
> start "Quantum GIS" /B "%OSGEO4W_ROOT%"\apps\qgis-dev\bin\qgis.exe %*
> Exactly the same as before the update.
> - Nathan
> On Thu, Mar 10, 2011 at 8:53 AM, Ramon Andinach <custard at westnet.com.au> wrote:
> On 10/03/2011, at 06:31 , Nathan Woodrow wrote:
> > Hi all,
> > I can't seem to open ecw files in the latest trunk build, I get a can "not open GDAL dataset {ecw name}" I was able to open them before the new raster OTF projection merge.
> > Running XP, QGIS r15395
> > Can anyone else confirm?
> You got an error message! Congratulations! You did better than me.
> (Are you sure it's not just that QGIS has forgotten where to look for the ECW libraries or GDAL plugins?)
