[Qgis-developer] Error opening ECW in latest trunk with OTF raster support.
Nathan Woodrow madmanwoo at gmail.com
Wed Mar 9 18:53:56 EST 2011
I seem to have got it working now.  It was a incorrect " dam file encoding
stuffed me up.  Although now it seems to be very slow at loading them.
- Nathan
On Thu, Mar 10, 2011 at 9:23 AM, Ramon Andinach <custard at westnet.com.au>wrote:
> That looks a lot like mine, which is loading ecw rasters so long as I don't
> turn OTF on.
> Sorry, I'm not able to help more.
> On 10/03/2011, at 06:59 , Nathan Woodrow wrote:
> > Pretty it knows where everything is; this is my qgis-dev.bat:
> > @echo off
> > SET OSGEO4W_ROOT=M:\TEMP\QGIS
> > call "%OSGEO4W_ROOT%"\bin\o4w_env.bat
> > call "%OSGEO4W_ROOT%"\bin\grass-env.bat
> > @echo off
> > path %PATH%;%GISBASE%\bin
> > set GDAL_DRIVER_PATH=”%OSGEO4W_ROOT%”\bin\gdalplugins\1.8
> > start "Quantum GIS" /B "%OSGEO4W_ROOT%"\apps\qgis-dev\bin\qgis.exe %*
> > Exactly the same as before the update.
> > - Nathan
> > On Thu, Mar 10, 2011 at 8:53 AM, Ramon Andinach <custard at westnet.com.au>
> wrote:
> > On 10/03/2011, at 06:31 , Nathan Woodrow wrote:
> > > Hi all,
> > > I can't seem to open ecw files in the latest trunk build, I get a can
> "not open GDAL dataset {ecw name}" I was able to open them before the new
> raster OTF projection merge.
> > > Running XP, QGIS r15395
> > > Can anyone else confirm?
> > You got an error message! Congratulations! You did better than me.
> > (Are you sure it's not just that QGIS has forgotten where to look for the
> ECW libraries or GDAL plugins?)
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110310/089e2e9f/attachment-0001.html
