[Qgis-developer] Qgis access control question
Mayeul Kauffmann mayeul.kauffmann at free.fr
Wed Mar 16 19:19:25 EDT 2011
Hi David,
Barry is right and his answer is much better than what you could get
with any client connecting to the data.
You can define read-only access for some users and write access to other
users both at the database level and at the shared disk level. All the
examples you gave (below) are normally managed this way. This is the
only safe way to do it: if you create a new client software managing
access restriction, you may always face users using other clients to
workaround those restrictions. On the contrary, whatever the client you
use, nobody will break a well designed database or shared disk security.
The only part of the access restrictions that a client as QGIS should
take care of is to ask users to provide a correct username/password, and
this is implemented.
Hope it helps.
Mayeul
Le mercredi 16 mars 2011 à 16:21 -0500, David Silva Barrera a écrit :
> For example an Analist just view and calculate areas and
> stadistics, but a Map-Administrator is responsible for updating new
> elements
> on maps, or modifying attributes.
