[Qgis-developer] Qgis access control question
David Silva Barrera
dsilva at uci.cu
Wed Mar 16 17:21:01 EDT 2011
I want a Qgis personalization where qgis must take care of socioeconomic
data for multiple users with different access level for both geographic and
socioeconomic data. For example an Analist just view and calculate areas and
stadistics, but a Map-Administrator is responsible for updating new elements
on maps, or modifying attributes.
For this typical scenario I prefer to apply control anywhere possible, so,
just show the user the permitted functionalities, just allow executing
related methods and just perform source-data access/modify right operations.
But, for example, qgisinterface is too open and will always be a restriction
about security while it's strength for extensibility.
Regards,
David
-----Mensaje original-----
De: b.rowlingson at googlemail.com [mailto:b.rowlingson at googlemail.com] En
nombre de Barry Rowlingson
Enviado el: miércoles, 16 de marzo de 2011 11:15 a.m
Para: David Silva Barrera
CC: qgis-developer at lists.osgeo.org
Asunto: Re: [Qgis-developer] Qgis access control question
On Wed, Mar 16, 2011 at 3:08 PM, David Silva Barrera <dsilva at uci.cu> wrote:
> Hi,
> Is there any development projection including functionalities for access
> control in Quantum? I mean, for example, role based access control or
> something.
> Im aware the actual code doesnt take care of this aspect cause of the
> actual objectives of Qgis application, but maybe someone have made steps
on
> this direction and could share ideas.
> I want to personalize Qgis for an specific business and security will be a
> priority aspect around.
Well, security is usually about access to data, and any application
should defer that to the operating system. So for example, if your
data is on shared drives, you'd control access via share permissions.
If your data is in a PostGIS database, you'd just use PostgreSQL user
access controls. Qgis doesn't enter into it.
What sort of thing did you have in mind?
Barry
