[Qgis-developer] Re: Value tool plugin makes QGIS crash
Giovanni Manghi giovanni.manghi at gmail.com
Sat Mar 26 16:54:12 EDT 2011
It also doesn't work with reprojected rasters.
> I tested/used the plugin extensively on both windows (seven) and linux
> (Ubuntu 32bit) in the last days and no crashes (qgis trunk and older
> versions).
> It works pretty good with *non* GRASS rasters, while with GRASS rasters
> is very slow (on Windows, acceptable on linux) and has another problem:
> when passing the mouse outside the extent of the raster it does not says
> "out of extent" and it doesn't show correctly the NULL pixels, as it
> continue to show the value of the last non NULL pixel where the mouse
> passed over.
> Do you want me to open a ticket?
> cheers
> -- Giovanni --
