[Qgis-developer] no python on fresh compile on natty
KOSZA Antal
antoniusz at clicknet.ro
Tue May 10 11:38:02 EDT 2011
2011. 05. 10, kedd keltezéssel 16.52-kor Richard Duivenvoorde ezt írta:
> It's a virgin natty install, only qgis related stuff on it is from
> apt-get build-dep, @Sandro: there should just be no 1.7 version...
> (can it be that the build-dep for natty is not ok??)
> First compile/install via svn sources: no working python, second run
> with clean build/source tree via git sources, still no python
> Tried 'locate qgis', but found nothing else then my sources and fresh
> install (even removed the install, compiled again etc)...
> I do have the latest sources in fefae90 isn't it?
> Richard
I have the same problem from 9 days ago, on debian sid, immediately
after libc upgrade (2.11>2.13), but building and installing the deb's,
python support works again.
Tóni
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110510/ba1c5d0f/attachment.bin
