[Qgis-developer] no python on fresh compile on natty
Giuseppe Sucameli
brush.tyler at gmail.com
Wed May 11 03:30:10 EDT 2011
Hi all,
it seems the same problem I had on my natty building qgis from source code.
I resolved putting /usr/lib/grass64 into /etc/ld.conf.d/libgrass64.conf (or something like that).
You could set an enviroment variable (LD_CONFIG, but I wouldn't to be wrong) instead of create the file above.
BTW, the problem I had shouldn't occur using deb packages.
I hope this can help.
Cheers.
On May 10, 2011, at 5:41 PM, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> Jürgen E. Fischer wrote:
>> Is your default python the python that you have PyQt and sip for?
> in synaptic:
> python-sip is showing: version 4.12.1-1 depends (python <2.8 >=2.6)
> python-qt4-dev: version 4.8.3-2 depends python-sip-dev, python-qt4(<4.3)
> installed python is 2.7.1, also checked by just running python and in errormsg: "/usr/lib/libpython2.7.so.1.0: undefined symbol: forkpty"
> there is also a python3-sip available in repo's, but I think that is only for python 3 which we do NOT use
> how to better check?
> Richard
> Qgis-developer mailing list
