[Qgis-developer] git clone through http proxy without ssh
Andreas Neumann
a.neumann at carto.net
Wed May 11 09:42:54 EDT 2011
I am trying to git clone through our https proxy with no luck. It seems
it requires port 22 to be open for checkout, but this port is closed at
my employer.
Here is the message I get:
git clone git at github.com:qgis/Quantum-GIS.git
Initialized empty Git repository in /home/an/dev/Quantum-GIS/.git/
ssh: connect to host github.com port 22: Connection timed out
fatal: The remote end hung up unexpectedly
Does git really require an ssh connection or is there a workaround?
btw - the following env vars are set:
$HTTP_PROXY
$http_proxy
$HTTPS_PROXY
$https_proxy
SVN works without a problem.
Thanks if you have any hints,
Andreas
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
