[Qgis-developer] git clone through http proxy without ssh
Pirmin Kalberer pi_ml at sourcepole.com
Wed May 11 09:59:25 EDT 2011
Hi Andreas,
git clone https://github.com/qgis/Quantum-GIS.git
should work with https_proxy.
Gruss
Pirmin
Am Mittwoch, 11. Mai 2011, 15.42:54 schrieb Andreas Neumann:
>  Hi,
>  I am trying to git clone through our https proxy with no luck. It seems
>  it requires port 22 to be open for checkout, but this port is closed at
>  my employer.
>  Here is the message I get:
>  git clone git at github.com:qgis/Quantum-GIS.git
>  Initialized empty Git repository in /home/an/dev/Quantum-GIS/.git/
>  ssh: connect to host github.com port 22: Connection timed out
>  fatal: The remote end hung up unexpectedly
>  Does git really require an ssh connection or is there a workaround?
>  btw - the following env vars are set:
>  $HTTP_PROXY
>  $http_proxy
>  $HTTPS_PROXY
>  $https_proxy
>  SVN works without a problem.
>  Thanks if you have any hints,
>  Andreas
Pirmin Kalberer
Sourcepole  -  Linux & Open Source Solutions
http://www.sourcepole.com
