[Qgis-developer] Qgis standalone app, sip version and API problems under mac os x
William Kyngesburye woklist at kyngchaos.com
Wed May 11 13:29:28 EDT 2011
Odd.  site-packages should be in the sys.path, so the plugin should find and import those modules.
On May 11, 2011, at 12:08 PM, Luca Mandolesi wrote:
> There should be no need to copy anything to inside QGIS.  site-packages is just another search path for Python to find things.
> mmmmh....if I don't copy the modules into Resources/python folder, plugins or others doesn't run properly.
> For example I'm using sqlalchemy, PIL and reportlab, and, if I don't copy the module into Qgis, the plugin cannot be opened...And I test it on few machines: mac mini, mac book pro, imac...
> Qgis-developer mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed robot?
[Marvin]  You think you have problems?  What are you supposed to do if you ARE a maniacally depressed robot?  No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
