[Qgis-developer] succesfull windows build from INSTALL text
Jürgen E. Fischer
jef at norbit.de
Fri May 13 14:36:21 EDT 2011
Hi Richard,
On Fri, 13. May 2011 at 17:30:37 +0200, Richard Duivenvoorde wrote:
> - the INSTALL text seems more up to date than the instructions on
> http://www.qgis.org/wiki/Building_QGIS_from_Source For example the INSTALL
> text already mentions the GIT stuff etc Should we not delete the wiki page,
> and for example just point to the INSTALL text?
ok, we update the wiki page now and then.
> - I never used GIT on windows, but googled msysgit
> http://code.google.com/p/msysgit/ which gives you a command line and I could
> do: git clone https://github.com/qgis/Quantum-GIS.git which worked...
You could also have used cygwin - Windows is pretty useless without it anyway
> - packaging:
> The packaging instructions are not clear to me. After compiling running it on
> windows, how to package it on ubuntu (for a 'real' windows user). What's the
> reason to not do it on windows itself?
That is on Windows. cygwin, remember? ;)
> - 32/64 bit
> Just tested this on 32-bit XP. Which worked fine!! Not sure if this would
> work on a 64 bit machine, or all links are then still working.
It does.
> - starting: after the install step in Visual Studio Express, all installed
> successfully in 'Program Files', but double clicking the executable (the
> windows way), I do not have Python stuff working. Using the cmake-start bat
> file (which set's all path's) I have a fully working python/qgis. Does
> somebody know what I have to copy/include/change to make the double clicking
> work?
Patch QGIS to include all the environment variables etc. the batch files set
up. I'd stick with the batch file as that's easier to customize.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
