[Qgis-developer] Qt5
Andreas Neumann
a.neumann at carto.net
Sun May 15 17:58:27 EDT 2011
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
hm - this is bad. SVG is quite essential for QGIS and its relation to
Inkscape and other vector graphics tools.
I don't think that QtWebkit would be a good enough replacement for
QtSVG. It is certainly much more capable for rendering than QtSVG, but
QGIS also needs QtSVG for writing. I don't think that QtWebkit could
handle that.
Maybe someone from the QGIS project could be the new maintainer of the
QtSVG code and improve it to our needs?
It would definitely worth having a look at other SVG libraries, such as
QtWebkit, librsvg, Inkscape or others, but it at the end it has to be a
read/write solution, not just a read solution.
I personally have a good understanding of SVG, but I am not a C++
programmer. I probably would be able to support an SVG effort
financially if someone could work on it.
Andreas
On 05/12/2011 07:27 PM, MORREALE Jean Roc wrote:
> Le 12/05/2011 19:12, Paolo Cavallini a écrit :
>> Il giorno gio, 12/05/2011 alle 19.08 +0200, MORREALE Jean Roc ha
>> scritto:
>>> Forget about an improved svg output with the actual QtSvg ->
>> So better drop it altogether?
>> All the best.
> He points to QtWebkit which have a full SVG implementation instead of
> the QtSvg's SVG Tiny
> Qgis-developer mailing list
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iQEcBAEBAgAGBQJN0Ex+AAoJELiCsGDopvBCtv0H/Rlqk+OlrbzQm7vWSgIIxwL+
I0Twvyi420b254EUjqeMrNQKbg+rrizE+ytAt+gunHzi8PAEZQjoLnrvsRvc07T/
pH0wMXP796/BPzvO8Rg7sIIHMN1IiuGd86MgIXVqnqCfB0wi+YQUc7Tj2Nl8hm5E
iIZbFR9iGC+utnuB/d0AJVS+fKFdAx/mcmnylKEUisMKmXt/XfvD6rrLKSsXpqAo
4G7BdPXopkyEoLXVknvoLjWBHJavEPsEXCG4y0gDtzeiwMddMXSatfA2cePSJaLN
x0NcIyLrUvjdzrVbB4/KOTZdeEC4hH26nON1yWw+yo6A81WE3cs9iVpSBLfIlfc=
=1l42
-----END PGP SIGNATURE-----
