[Qgis-developer] no python on fresh compile on natty FIXED
Marco Bernasocchi marco at bernawebdesign.ch
Fri May 20 10:10:44 EDT 2011
Could anybody find a solution for this without using LD_PRELOAD? I tried
with no luck. (the LD_PRELOAD hack works)
ciao
Marco
On 05/13/2011 11:23 AM, Richard Duivenvoorde wrote:
> On 05/10/2011 12:59 PM, Richard Duivenvoorde wrote:
>> Hi py-devs,
>> installed Ubuntu 11.04 on laptop and trying to compile qgis from svn
>> (r15866).
>> compiling (debug mode) ends ok, no errors or so, but I do not have python
>> (though there is a non working menu-item 'python-console').
>> Warning: Couldn't load Python support library: Cannot load library
>> /home/richard/apps/qgis/trunk/debug/lib/qgispython:
>> (/usr/lib/libpython2.7.so.1.0: undefined symbol: forkpty, version
>> GLIBC_2.0)
>> Any idea?
> Don't know the technical details, but (thanks Tóni)
> https://code.google.com/p/modwsgi/wiki/InstallationIssues pointed to:
> After compilation, locate your libutil lib on Natty:
> /usr/lib/i386-linux-gnu/libutil.so
> Now do
> LD_PRELOAD=/usr/lib/i386-linux-gnu/libutil.so
> export LD_PRELOAD
> now run Qgis
> Strange thing is that the nightly builds of qgis run fine...
> So apparently I miss some linking magic ???
> Regards,
> Richard
> Qgis-developer mailing list
