[Qgis-developer] Exception "Access Violation No RTTI-Data!" on
windows XP (32 bit)
Alister Hood
alister.hood at synergine.com
Tue May 24 17:40:20 EDT 2011
For what it's worth I get this message reasonably often at the moment,
so I'd be more inclined to think it was _caused_ by the changes to the
TOC. I imagine the same message could have been produced by several
different underlying problems though.
I know I get it when simply changing symbologies, but I think once or
twice I've got it doing other things. I'm currently using a very
complex project with a lot of layers and rule based rendering with a lot
of rules.
Alister
> Date: Tue, 24 May 2011 20:22:00 +0100
> From: Giovanni Manghi <giovanni.manghi at gmail.com>
> Subject: Re: [Qgis-developer] Exception "Access Violation No RTTI-
> Data!" on windows XP (32 bit)
> To: maaza mekuria <sailmcm at yahoo.com>
> Cc: qgis-dev <qgis-developer at lists.osgeo.org>
> Message-ID: <1306264920.12688.155.camel at sibirica>
> Content-Type: text/plain; charset="UTF-8"
> Hi,
> I recall that the error had something related with the TOC. Since the
> TOC has been upgraded to included nested groups and multiple layer
> selection the error seems to have gone.
> On another note: what does your plugin? do you plan to contribute it?
> Cheers
> -- Giovanni --
> On Mon, 2011-05-23 at 12:45 -0700, maaza mekuria wrote:
> > I am getting the error "Access Violation No RTTI- Data!" while I
am
> > running my C++ plugin. I checked out on the web to see what if it
was
> > reported by anyone, and I found some references about a year ago. I
am
> > not sure if any of you have come across of the same and know why it
is
> > due to. The plugin does not crash but I am not able to find out what
> > is causing it. I am opening multiple layer data using the layer data
> > providers (shape file layers on the canvas.) and nothing more
> > unusual.
> > The web problems were reported about a year ago and I can not see
what
> > was the resolution except the new version seemed to take of it.
> > Thank you,
> > Maaza
