[Qgis-developer] DBManager plugin for QuantumGIS (GSoC 2001)
Martin Dobias
wonder.sk at gmail.com
Wed May 25 09:43:11 EDT 2011
Hi all
just a quick reaction from my side (sorry for being so brief):
- it is quite unfair with Guiseppe if you people start proposing how
things should be done _now_ - IMO there was plenty of time to do such
decisions before
- I think it is quite irrelevant whether the implementation is in C++
or in Python: in case the interfaces (such as QgsDataItem) are
implemented correctly there is no real difference (if the code is
shipped with QGIS).
- it has been decided in the proposal that support for saving vector
layers to a particular data providers will be implemented to get
generic vector import/export, the rest of the code is not going to be
that reusable anyway.
- the Qbrowser API is IMHO not completely finished and still might see
some changes. This might cause additional complications for Giuseppe.
So in general I would suggest proceeding with the original plan and to
try to integrate some parts into QBrowser - e.g. implement QgsDataItem
support for PostGIS and SpatiaLite, together with the paramWidget()
that might reuse a lot of work from the db manager plugin itself.
Regards
Martin
On 5/25/11, Giuseppe Sucameli <brush.tyler at gmail.com> wrote:
> On Wed, May 25, 2011 at 1:21 PM, Radim Blazek <radim.blazek at gmail.com>wrote:
>> On Wed, May 25, 2011 at 10:39 AM, Giuseppe Sucameli
>> wrote:
>> > However we should consider to integrate useful python plugins in qgis
>> code, porting
>> > their base functions to C++ if necessary.
>> So why to write another important plugin in Python, with perspective
>> that it has to be ported later to C++?
> Again, I would develop in python the GUI only, not the base functions ;)
> Tell me what in the QBrowser class cannot be done in python, it's just a
> container. It uses the QgsBrowserModel and some other Qt based classes
> I can easily handle in python without any problem.
> I don't think the QBrowser code makes particular GUI widgets/functions we
> should insert in app/core/gui. Different would be if you had developed a
> QgsBrowser tree widget implementing also the QgsLegend interface, as
> everybody could reuse that.
> However, discussing it we're also going to find what the current
> implementation
> misses and what should be changed, doesn't matter if at the end it will be
> done in C++ or python. It will be Martin who has to decide.
> No other devs want to partecipate to the discussion? ;)
> I think that a lot of interesting things are coming out.
> Regards.
> Giuseppe Sucameli
