[Qgis-developer] QGIS Web Client migrated to GIT
Tim Sutton lists at linfiniti.com
Fri May 27 05:26:25 EDT 2011
Hi
On Fri, May 27, 2011 at 11:14 AM, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Tim,
> The changes you describe sound fine to me.
Ok great
> My osgeo username is "neumann", I believe the same username was also used in
> svn.
You should have commit access to the repo now.
I would need access to the documentation (manual) and to the QGIS
> webclient parts of the repository.
The manual is not yet ported to git - Otto and I discussed this and
agreed to wait until after they have release the 1.7 manual before
doing this. I will add any committers to the git repo at that point.
The web client is in its own repo (git philosophy being 1 project 1
repo so we dont have many things in 1 heirarchy like we had in svn).
Best regards
Tim
> Andreas
> On Fri, 27 May 2011 11:05:48 +0200, Tim Sutton wrote:
>> Hi Andreas
>> On Fri, May 27, 2011 at 10:42 AM, Andreas Neumann
>>> Hi Tim,
>>> Thanks for the migration. I had a meeting with Pirmin yesterday and we
>>> started a redmine project for QGIS web client. We already filed a few
>>> bugs
>>> where I don't yet have a solution: see
>>> http://hub.qgis.org/projects/qgis-web-client
>> Ok cool. I added myself to the manager list there.
>>> I think we should also offer a mobile client for Smartphones/Tablets in
>>> the
>>> future based on the newer OpenLayers version. I won't have time before
>>> autumn to work on it, but maybe someone else wants to start earlier.
>> For me its not a priority as well - I am doing some work for a client
>> and they have agreed we can contribute any improvements back to the
>> web client project so I will try to make my changes in a generic way
>> as far as possible.
>>>> We will be doing some refactoring to try to make better separation of
>>>> the user configurable parts from the generic parts. Most likely we
>>>> will just rename user configurable files to .templ and provide
>>>> instructions that those files should be copied like so:
>>>> cp file.templ file
>>>> When setting up the project. We will document the procedures required
>>>> etc.
>>> I do not understand the idea with the .templ files. I actually tried to
>>> keep
>>> everything "configurable" in the file js/GlobalOptions.js - do you think
>>> there are additional parameters that need to be configurable?
>> In our testing there are three files that need configuring:
>> - index.html (we added this to make a more user friendly landing page
>> so that user doesnt need to remember urls with ?map=foo in them.
>> - index.xml (at the moment this has Uster specific stuff in)
>> - js/GlobalOptions (also has project specific stuff in it)
>> We didnt implement search stuff here yet so that would also get added
>> to the above list probably.
>> We want to separate anything that the user will change in his
>> deployment from stuff that is version controlled in git. This way a
>> user makes no fork of the project when he customises it for his site,
>> and can benifit from upstream updates and improvements.
>> We also rename icons to gis_icons by the way because if you deploy it
>> in the default apache route the /icons alias is already take by apache
>> and no icons show in the ui.
>> I'm also making more changes to my own fork which creates more of a
>> directory structure and tries to make it as easy as possible for a new
>> project to be deployed. It looks something like this for me at the
>> moment:
>> ├── apache-conf
>> ├── cgi-bin
>> ├── data
>> ├── readme.txt
>> ├── sample_wms_requests.txt
>> ├── site
>> └── wsgi
>> I am creating a simple hello world project too so that when using a
>> default deployment, the user gets a working usable app out of the box.
>> The data for the project is included in the repo i a simple
>> spatiallite db.
>> Hopefully these updates are acceptible for you and Pirmin (and others
>> interested).
>>>> Those who need access to the QGIS Web Client team so that they can
>>>> push directly to the official repo please let me know and I will add
>>>> you.
>>> Can you please add me?
>> Sure - can you confirm your github user name please?
>> Thanks
>> Tim
>>> Thanks,
>>> Andreas
>>> Andreas Neumann
>>> Böschacherstrasse 10A
>>> 8624 Grüt (Gossau ZH)
>>> Switzerland
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Visit http://linfiniti.com to find out about:
>>  * QGIS programming and support services
>>  * Mapserver and PostGIS based hosting plans
>>  * FOSS Consulting Services
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
> Andreas Neumann
> Switzerland
Skype: timlinux
