[Qgis-developer] QGIS Web Client migrated to GIT
Andreas Neumann a.neumann at carto.net
Fri May 27 05:14:38 EDT 2011
 Hi Tim,
 The changes you describe sound fine to me.
 My osgeo username is "neumann", I believe the same username was also
 used in svn. I would need access to the documentation (manual) and to
 the QGIS webclient parts of the repository.
 Andreas
 On Fri, 27 May 2011 11:05:48 +0200, Tim Sutton wrote:
> Hi Andreas
> On Fri, May 27, 2011 at 10:42 AM, Andreas Neumann
> <a.neumann at carto.net> wrote:
>> Hi Tim,
>> Thanks for the migration. I had a meeting with Pirmin yesterday and
>> we
>> started a redmine project for QGIS web client. We already filed a
>> few bugs
>> where I don't yet have a solution: see
>> http://hub.qgis.org/projects/qgis-web-client
> Ok cool. I added myself to the manager list there.
>> I think we should also offer a mobile client for Smartphones/Tablets
>> in the
>> future based on the newer OpenLayers version. I won't have time
>> before
>> autumn to work on it, but maybe someone else wants to start earlier.
> For me its not a priority as well - I am doing some work for a client
> and they have agreed we can contribute any improvements back to the
> web client project so I will try to make my changes in a generic way
> as far as possible.
>>> We will be doing some refactoring to try to make better separation
>>> of
>>> the user configurable parts from the generic parts. Most likely we
>>> will just rename user configurable files to .templ and provide
>>> instructions that those files should be copied like so:
>>> cp file.templ file
>>> When setting up the project. We will document the procedures
>>> required etc.
>> I do not understand the idea with the .templ files. I actually tried
>> to keep
>> everything "configurable" in the file js/GlobalOptions.js - do you
>> think
>> there are additional parameters that need to be configurable?
> In our testing there are three files that need configuring:
> - index.html (we added this to make a more user friendly landing page
> so that user doesnt need to remember urls with ?map=foo in them.
> - index.xml (at the moment this has Uster specific stuff in)
> - js/GlobalOptions (also has project specific stuff in it)
> We didnt implement search stuff here yet so that would also get added
> to the above list probably.
> We want to separate anything that the user will change in his
> deployment from stuff that is version controlled in git. This way a
> user makes no fork of the project when he customises it for his site,
> and can benifit from upstream updates and improvements.
> We also rename icons to gis_icons by the way because if you deploy it
> in the default apache route the /icons alias is already take by
> apache
> and no icons show in the ui.
> I'm also making more changes to my own fork which creates more of a
> directory structure and tries to make it as easy as possible for a
> new
> project to be deployed. It looks something like this for me at the
> moment:
> ├── apache-conf
> ├── cgi-bin
> ├── data
> ├── readme.txt
> ├── sample_wms_requests.txt
> ├── site
> └── wsgi
> I am creating a simple hello world project too so that when using a
> default deployment, the user gets a working usable app out of the
> box.
> The data for the project is included in the repo i a simple
> spatiallite db.
> Hopefully these updates are acceptible for you and Pirmin (and others
> interested).
>>> Those who need access to the QGIS Web Client team so that they can
>>> push directly to the official repo please let me know and I will
>>> add
>>> you.
>> Can you please add me?
> Sure - can you confirm your github user name please?
> Thanks
> Tim
>> Thanks,
>> Andreas
>> Andreas Neumann
>> Böschacherstrasse 10A
>> 8624 Grüt (Gossau ZH)
>> Switzerland
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release
> Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
>  * QGIS programming and support services
>  * Mapserver and PostGIS based hosting plans
>  * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
 Andreas Neumann
 Switzerland
