[Qgis-developer] Install Globe on ubuntu!
Andreas Neumann a.neumann at carto.net
Sun May 29 15:17:21 EDT 2011
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I suspect that it has nothing to do with globe but with the change of
libraries from version 1.7 to version 1.8.
When I change from one version to another I usually have to delete the
old libraries /usr/local/lib/libqgis*1.7* and then run ldconfig
Then compile and install should work fine. For some reasons, newer
compiles can link to older versions of the libqgis*
Maybe this helps if you manually delete old library versions?
Andreas
On 05/29/2011 08:57 PM, Marco Bernasocchi wrote:
> Salut Fred,
> The report you give is not super verbose. The error probably happened
> earlyer, scroll up in the terminal and look for the error. Furthermore try
> to re launch the make step:
> cd builDir
> make ..
> Hope it helps
> Marco
> (sent from my mobile)
> On 29 May 2011 19:53, "Fred ETHEVE" <fred.etheve at wanadoo.fr> wrote:
> Qgis-developer mailing list
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iQEcBAEBAgAGBQJN4pu8AAoJELiCsGDopvBCDPcIAIdpwxiolh/vAVwXRgaTfUuJ
qCytOKvG4yhBOeGNsQi5G6wbI34vKXJp6XXuOl9s0WXwRAZB03zfYwt+qYqmqTR8
9pRB6ef9/JGpAfc2xTRydcsHcyHlcQ07C9u0TN6mCcrRns1052R/36t8dJgZQMhu
8uL3J5GAruitqALg7LfCvx3gkqiohDREvtyPb1I5YGoQil8p2dGqyKhIk07H3mmf
v4ZpbTu8h5QiAzFMU06hu37Hq0nDVG4igZqt+eVMUKAh1JK1uGaENKbmqZmBhImO
Sguay41kgg+3vkqU8KE/wLqWCB5GKlxm15x/cyvb4DYYxp/nnbxvGhwLSacnnAg=
=iAnl
-----END PGP SIGNATURE-----
