[Qgis-developer] Install Globe on ubuntu!
Fred ETHEVE
fred.etheve at wanadoo.fr
Sun May 29 17:06:07 EDT 2011
Salut, Marco,
Thank you,
So ive made « make VERBOSE=1
And there is the end of the verbose (you want the beginning?), with error :
[ 70%] Building CXX object
src/providers/grass/CMakeFiles/grassprovider.dir/qgsgrassprovider.cpp.o
cd /home/fred/globe/qgis/build/src/providers/grass && /usr/bin/c++
-Dgrassprovider_EXPORTS -DQT_SVG_LIB -DQT_WEBKIT_LIB -DQT_GUI_LIB
-DQT_XML_LIB -DQT_SQL_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB
-DQT_NO_CAST_TO_ASCII -DQGISDEBUG=1 -DQT_DEBUG -g -fPIC -I/usr/include/qt4
-I/usr/include/qt4/QtSvg -I/usr/include/qt4/QtWebKit
-I/usr/include/qt4/QtGui -I/usr/include/qt4/QtXml -I/usr/include/qt4/QtSql
-I/usr/include/qt4/QtNetwork -I/usr/include/qt4/QtCore
-I/home/fred/globe/qgis/build
-I/home/fred/globe/qgis/src/providers/grass/../../core
-I/home/fred/globe/qgis/src/providers/grass/../../core/raster
-I/usr/lib/grass64/include -I/usr/include/gdal -Wall -Wno-long-long
-Wformat-security -Wno-strict-aliasing -DCORE_EXPORT= -DGUI_EXPORT=
-DPYTHON_EXPORT= -DANALYSIS_EXPORT= -DGRASS_BASE=\"/usr/lib/grass64/lib\"
-DGRASS_EXPORT= -o CMakeFiles/grassprovider.dir/qgsgrassprovider.cpp.o -c
/home/fred/globe/qgis/src/providers/grass/qgsgrassprovider.cpp
/home/fred/globe/qgis/src/providers/grass/qgsgrassprovider.cpp: In member
function virtual QVector<QgsDataItem*>
QgsGrassMapsetItem::createChildren():
/home/fred/globe/qgis/src/providers/grass/qgsgrassprovider.cpp:2447:79:
error: call of overloaded QString(int) is ambiguous
/usr/include/qt4/QtCore/qstring.h:428:43: note: candidates are:
QString::QString(const QByteArray&)
/usr/include/qt4/QtCore/qstring.h:426:43: note:
QString::QString(const char*)
/usr/include/qt4/QtCore/qstring.h:728:8: note:
QString::QString(const QString&)
/usr/include/qt4/QtCore/qstring.h:106:5: note:
QString::QString(QChar)
/usr/include/qt4/QtCore/qstring.h:105:14: note:
QString::QString(const QChar*)
make[2]: ***
[src/providers/grass/CMakeFiles/grassprovider.dir/qgsgrassprovider.cpp.o]
Erreur 1
make[2]: quittant le répertoire « /home/fred/globe/qgis/build »
make[1]: *** [src/providers/grass/CMakeFiles/grassprovider.dir/all] Erreur 2
make[1]: quittant le répertoire « /home/fred/globe/qgis/build »
make: *** [all] Erreur 2
fred at HP:~/globe/qgis/build$
cheers
De : Marco Bernasocchi [mailto:marco at bernawebdesign.ch]
Envoyé : dimanche 29 mai 2011 20:57
À : Fred ETHEVE
Cc : qgis-developer at lists.osgeo.org
Objet : Re: [Qgis-developer] Install Globe on ubuntu!
Salut Fred,
The report you give is not super verbose. The error probably happened
earlyer, scroll up in the terminal and look for the error. Furthermore try
to re launch the make step:
cd builDir
make ..
Hope it helps
Marco
(sent from my mobile)
On 29 May 2011 19:53, "Fred ETHEVE" <fred.etheve at wanadoo.fr> wrote:
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110529/2a9eb788/attachment-0001.html
