[Qgis-developer] grass provider linking weirdness
Jürgen E. Fischer jef at norbit.de
Mon May 30 02:53:02 EDT 2011
Hi William,
On Sun, 29. May 2011 at 20:31:14 -0500, William Kyngesburye wrote:
> I noticed that the grass provider is now a library instead of a module, and
> is linked to by the grass plugin.  If there are functions the grass plugin
> needs from the grass provider, shouldn't they be moved to the qgisgrass
> library and leave the provider as a module?  It's messed up the Mac install
> processing, at least.
>From my POV the grass provider linking weirdness is gone now. ;)
grassprovider.cpp was linked into both the library and the provider.  Now it's
only in the provider and the provider is also linked to the plugin as it needs
some methods from the provider.
What's the problem on mac with that?
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
