[Qgis-developer] Get the qgis project into the browser...
Christopher Stark
christopherstark at gmx.de
Mon Nov 7 10:28:02 EST 2011
I tried to make this qgis project visible in the browser:
http://www.christopherstark.de/extern/qgis-server2.jpg
I installed qgis server and it seems to work. When I use this URL below
(I think I changed it correctly to my settings) in the browser there is
only a white screen and no map.
http://localhost/cgi-bin/qgistest1/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=54.215710,10.017432,50.05100,15.0004508&CRS=EPSG:4326&WIDTH=1077&HEIGHT=552&LAYERS=ostdeutschland-mercator2&FORMAT=image/png&DPI=96
Can anyone here help me to get the right url in order to make the map
visible in the browser?
best regards
Christopher
Am 19.10.2011 10:39, schrieb Noli Sicad:
> I guess you have read this,
> Noli
> On 10/19/11, Noli Sicad <nsicad at gmail.com> wrote:
>> Hi Christopher,
>> The code that I posted is not complete.
>> Did you include OpenLayers.js and CSS for the openlayers?
>> Visit this link and to see the whole code,
>> http://linfiniti.com/2011/09/qgis-server-with-tilecache/
>> It seem the link is not working now. However, you browse the any
>> openlayers example and see how the post that I copied from Tim's is
>> used.
>> Noli
>> On 10/19/11, Christopher Stark <christopherstark at gmx.de> wrote:
>>> Hi Noli,
>>> which parts in this code do I have to modify for my Qgis Server Project?
>>> I pasted this code into a html (index2.html) file within var/www/ but
>>> there is nothing displayed when I open
>>> localhost/index2.html
>>> best regards
>>> Christopher
>>> Am 16.10.2011 04:40, schrieb Noli Sicad:
>>>>> The most common web client being Openlayers, this will require work on
>>>>> your part, mainly a few lines of javascript in a web page. You might be
>>>>> able to use it directly in Geocommons or in Mapfish (also takes setup).
>>>> This is how Tim used it for OpenLayers client (below).
>>>> Very few documentation how to actually use in OpenLayers and WMS.
>>>> Noli
>>>> <script type="text/javascript">
>>>> var map, layer;
>>>> function init(){
>>>> var MapOptions = {
>>>> projection: new OpenLayers.Projection("EPSG:32633"),
>>>> units: "m",
>>>> masxScale: 19567.879237500,
>>>> //maxScale:1000,
>>>> //minScale:17000000,
>>>> numZoomLevels: 10,
>>>> resolutions: [19567.8792375, 9783.93961875,
>>>> 4891.969809375, 2445.9849046875, 1222.99245234375, 611.496226171875,
>>>> 305.7481130859375, 152.87405654296876, 76.43702827148438,
>>>> 38.21851413574219],
>>>> maxExtent: new
>>>> OpenLayers.Bounds(-918304.23600184,6418410.00099619,1957227.50491800,7976533.94886646),
>>>> fractionalZoom: false,
>>>> transitionEffect:"resize",
>>>> map = new OpenLayers.Map( 'map', MapOptions );
>>>> layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
>>>> "http://maps.linfiniti.com/cgi-bin/tilecache.cgi",
>>>> {layers: 'utno-test'} );
>>>> map.addLayer(layer);
>>>> map.zoomToMaxExtent();
>>>> </script>
>>>> </head>
>>>> <body onload="init()">
>>>> <div id="map" class="map"></div>
>>>> </body>
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111107/56ec4a6c/attachment-0001.html
