[Qgis-developer] Get the qgis project into the browser...
Andreas Neumann a.neumann at carto.net
Mon Nov 7 14:59:09 EST 2011
Hi Christopher,
What are your goals? To setup a WMS server or to setup a Web-GIS with
QGIS Webclient?
One option to test if QGIS server is working properly as a WMS server,
is to use QGIS desktop as a WMS client.
QGIS web client is a different story to setup. First let us know what
your goals are.
Andreas
On 11/07/2011 04:28 PM, Christopher Stark wrote:
> Hi,
> I tried to make this qgis project visible  in the browser:
> http://www.christopherstark.de/extern/qgis-server2.jpg
> I installed qgis server and it seems to work. When I use this URL below
> (I think I changed it correctly to my settings) in the browser there is
> only a white screen and no map.
> http://localhost/cgi-bin/qgistest1/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=54.215710,10.017432,50.05100,15.0004508&CRS=EPSG:4326&WIDTH=1077&HEIGHT=552&LAYERS=ostdeutschland-mercator2&FORMAT=image/png&DPI=96
> Can anyone here help me to get the right url in order to make the map
> visible in the browser?
> best regards
> Christopher
> Am 19.10.2011 10:39, schrieb Noli Sicad:
>> I guess you have read this,
>> Noli
>> On 10/19/11, Noli Sicad <nsicad at gmail.com> wrote:
>>> Hi Christopher,
>>> The code that I posted is not complete.
>>> Did you include OpenLayers.js and CSS for the openlayers?
>>> Visit this link and to see the whole code,
>>> http://linfiniti.com/2011/09/qgis-server-with-tilecache/
>>> It seem the link is not working now. However, you browse the any
>>> openlayers example and see how the post that I copied from Tim's is
>>> used.
>>> Noli
>>> On 10/19/11, Christopher Stark <christopherstark at gmx.de> wrote:
>>>> Hi Noli,
>>>> which parts in this code do I have to modify for my Qgis Server Project?
>>>> I pasted this code into a html (index2.html) file within var/www/  but
>>>> there is nothing displayed when I open
>>>> localhost/index2.html
>>>> best regards
>>>> Christopher
>>>> Am 16.10.2011 04:40, schrieb Noli Sicad:
>>>>>> The most common web client being Openlayers, this will require work on
>>>>>> your part, mainly a few lines of javascript in a web page. You might be
>>>>>> able to use it directly in Geocommons or in Mapfish (also takes setup).
>>>>> This is how Tim used it for OpenLayers client (below).
>>>>> Very few documentation how to actually use in OpenLayers and WMS.
>>>>> Noli
>>>>> <script type="text/javascript">
>>>>>         var map, layer;
>>>>>         function init(){
>>>>>           var MapOptions = {
>>>>>             projection: new OpenLayers.Projection("EPSG:32633"),
>>>>>             units: "m",
>>>>>             masxScale: 19567.879237500,
>>>>>             //maxScale:1000,
>>>>>             //minScale:17000000,
>>>>>             numZoomLevels: 10,
>>>>>             resolutions: [19567.8792375, 9783.93961875,
>>>>> 4891.969809375, 2445.9849046875, 1222.99245234375, 611.496226171875,
>>>>> 305.7481130859375, 152.87405654296876, 76.43702827148438,
>>>>> 38.21851413574219],
>>>>>             maxExtent: new
>>>>> OpenLayers.Bounds(-918304.23600184,6418410.00099619,1957227.50491800,7976533.94886646),
>>>>>             fractionalZoom: false,
>>>>>             transitionEffect:"resize",
>>>>>           map = new OpenLayers.Map( 'map', MapOptions );
>>>>>           layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
>>>>>               "http://maps.linfiniti.com/cgi-bin/tilecache.cgi",
>>>>>               {layers: 'utno-test'} );
>>>>>           map.addLayer(layer);
>>>>>           map.zoomToMaxExtent();
>>>>>     </script>
>>>>>   </head>
>>>>>   <body onload="init()">
>>>>>     <div id="map" class="map"></div>
>>>>>   </body>
>>>>> _______________________________________________
>>>>> Qgis-developer mailing list
>>>>> Qgis-developer at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
