[Qgis-developer] New plugin repo now a default in QGIS master
Alex Mandel
tech_dev at wildintellect.com
Sat Nov 12 15:57:13 EST 2011
The Redmine interface lets the owner of the plugin decide who else has
read/write(pull/push) to the plugin code over standard git methods (ssh
key based, just like github). Read-only over http and the web interface
is provided by default to the public.
So basically you can grant git permissions via the project properties
for your plugins. The actual code handling is done by gitosis on the
backend.
Thanks,
Alex
On 11/12/2011 12:41 PM, kimaidou wrote:
> Since I was the one confused, I would like to thank you for clearing this
> up :)
> One addition : Qgis hub is also the place to share the plugin source code,
> using the "repository" option. I am not sure though if the repo linked with
> a redmine project is only readable, or if users would be allowed to
> push/pull through redmine
> (in my company, we use redmine only to show the changesets of repositories.
> We push and pull throuh ssh connections for better control and safety)
> Cheers
> kimaidou
> 2011/11/12 Giuseppe Sucameli <sucameli at faunalia.it>
>> Hi all,
>> looking at IRC seems there's some confusion about which is the
>> right site to upload a plugin to the new repo.
>> On Sat, Nov 12, 2011 at 12:42 PM, Tim Sutton <lists at linfiniti.com> wrote:
>>> we have added the new repo as a default in QGIS so that
>>> users can start to use it and stress test it before 2.0 gets released.
>> The Quantum GIS Plugin Repository (plugins.qgis.org) [1] is the
>> web site to share your plugins.
>> You can upload a new plugin or just see the state of the previous
>> uploaded ones, which versions, if it was approved, and so on.
>> The other site [2] is instead the QGis Plugins Issue tracking system.
>> Creating a trac instance once uploaded a new plugin on the QGis
>> Plugin Repository site is optional, but it gives users a place to report
>> problems that occur using a plugin.
>> I hope this helps.
>> Regards.
>> [1] http://plugins.qgis.org
>> [2] http://hub.qgis.org/projects/qgis-user-plugins
>>> Regards
>>> Tim
