[Qgis-developer] New plugin repo now a default in QGIS master
kimaidou
kimaidou at gmail.com
Sat Nov 12 15:41:11 EST 2011
Since I was the one confused, I would like to thank you for clearing this
up :)
One addition : Qgis hub is also the place to share the plugin source code,
using the "repository" option. I am not sure though if the repo linked with
a redmine project is only readable, or if users would be allowed to
push/pull through redmine
(in my company, we use redmine only to show the changesets of repositories.
We push and pull throuh ssh connections for better control and safety)
Cheers
kimaidou
2011/11/12 Giuseppe Sucameli <sucameli at faunalia.it>
> Hi all,
> looking at IRC seems there's some confusion about which is the
> right site to upload a plugin to the new repo.
> On Sat, Nov 12, 2011 at 12:42 PM, Tim Sutton <lists at linfiniti.com> wrote:
> > we have added the new repo as a default in QGIS so that
> > users can start to use it and stress test it before 2.0 gets released.
> The Quantum GIS Plugin Repository (plugins.qgis.org) [1] is the
> web site to share your plugins.
> You can upload a new plugin or just see the state of the previous
> uploaded ones, which versions, if it was approved, and so on.
> The other site [2] is instead the QGis Plugins Issue tracking system.
> Creating a trac instance once uploaded a new plugin on the QGis
> Plugin Repository site is optional, but it gives users a place to report
> problems that occur using a plugin.
> I hope this helps.
> Regards.
> [1] http://plugins.qgis.org
> [2] http://hub.qgis.org/projects/qgis-user-plugins
> > Regards
> > Tim
> > Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> > Please do not email me off-list with technical
> > support questions. Using the lists will gain
> > more exposure for your issues and the knowledge
> > surrounding your issue will be shared with all.
> > Visit http://linfiniti.com to find out about:
> > * QGIS programming and support services
> > * Mapserver and PostGIS based hosting plans
> > * FOSS Consulting Services
> > Skype: timlinux
> > Irc: timlinux on #qgis at freenode.net
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111112/ed9ee599/attachment.html
