[Qgis-developer] Georeferencer Plugin - OS X 1.7.1 UI Glitch - be
working in 1.7.2?
Noli Sicad
nsicad at gmail.com
Mon Nov 14 00:43:59 EST 2011
Any resolution to make Georeferencing Plugin (C++) working in Mac OS X
for QGIS 1.7.2
It is working in Ubuntu and I think it is also working in Windows
since we heard no complains. However, it is not working in Mac OS X.
I hope this would be fixed in QGIS 1.7.2 release.
Noli
Date: Thu, 10 Nov 2011 19:36:04 -0800
Subject: [Qgis-user] Georeferencer Plugin - OS X 1.7.1 UI Glitch
To: qgis-user at lists.osgeo.org
I concur that the Georeferencing is not working that well in OS X.
When you select a reference point in the Raster it pops up a Enter map
coordinates window
When you ask to select from map canvas the Georeferencer window hides
Once you select the map canvas co-ordinate, the Georeferencer window
unhides BUT
The Enter map coordinates window becomes buried behind every QGIS Window as
last priority.
The Enter map coordinates window needs to be "Always On Top"
Tested on 1.7.1
mars
On Wed, Nov 9, 2011 at 7:48 PM, Noli Sicad <nsicad at gmail.com> wrote:
> Good to know that QGIS in Mac OS X is getting stable.
> However, there are 2 things that it is not working in QGIS Mac OS X, right
> now.
> 1. Georeferencing plugin (C++ plugin).
> 2. Rectangle, Oval and Diamonds (Digitizing) python plugin.
> These 2 plugins are working properly properly in Ubuntu 10.04.
> (I have 3 triple laptop (Window 7, Mac OS X (10.6.4) and Ubuntu
> 10.04), so I can switch back and forth from Mac OS X and Ubuntu at the
> moment. Windows 7 is dormant at moment).
> I prefer to use Mac OS X with QGIS since I could run several version
> of QGIS by just renaming QGIS and installed another version).
> Thanks.
> Noli
