[Qgis-developer] Georeferencer Plugin - OS X 1.7.1 UI Glitch - be working in 1.7.2?
William Kyngesburye woklist at kyngchaos.com
Mon Nov 14 20:49:31 EST 2011
Well, it hasn't improved, but thanks to Mars I figured out the problem better and it is usable.  I'll put a note in the readme when I package up 1.7.2 (see the bug report also).
On Nov 13, 2011, at 11:43 PM, Noli Sicad wrote:
> Hi,
> Any resolution to make Georeferencing Plugin (C++) working in Mac OS X
> for QGIS 1.7.2
> It is working in Ubuntu and I think it is also working in Windows
> since we heard no complains. However, it is not working in Mac OS X.
> I hope this would be fixed in QGIS 1.7.2 release.
> Noli
> Date: Thu, 10 Nov 2011 19:36:04 -0800
> Subject: [Qgis-user] Georeferencer Plugin - OS X 1.7.1 UI Glitch
> To: qgis-user at lists.osgeo.org
> I concur that the Georeferencing is not working that well in OS X.
> When you select a reference point in the Raster it pops up a Enter map
> coordinates window
> When you ask to select from map canvas the Georeferencer window hides
> Once you select the map canvas co-ordinate, the Georeferencer window
> unhides BUT
> The Enter map coordinates window becomes buried behind every QGIS Window as
> last priority.
> The Enter map coordinates window needs to be "Always On Top"
> Tested on 1.7.1
> mars
> On Wed, Nov 9, 2011 at 7:48 PM, Noli Sicad <nsicad at gmail.com> wrote:
>> Good to know that QGIS in Mac OS X is getting stable.
>> However, there are 2 things that it is not working in QGIS Mac OS X, right
>> now.
>> 1. Georeferencing plugin (C++ plugin).
>> 2. Rectangle, Oval and Diamonds (Digitizing) python plugin.
>> These 2 plugins are working properly properly in Ubuntu 10.04.
>> (I have 3 triple laptop (Window 7, Mac OS X (10.6.4) and Ubuntu
>> 10.04), so I can switch back and forth from Mac OS X and Ubuntu at the
>> moment. Windows 7 is dormant at moment).
>> I prefer to use Mac OS X with QGIS since I could run several version
>> of QGIS by just renaming QGIS and installed another version).
>> Thanks.
>> Noli
> Qgis-developer mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
- the wisdom of Tarzan
