[Qgis-developer] Proposed attribute table UI redesign
Anita Graser
anitagraser at gmx.at
Mon Nov 14 06:05:37 EST 2011
Hi Andreas,
Is there a document that describes your plans concerning attribute table
and forms?
It would be good to add it to a central summary of developer meeting
results.
Thanks,
Anita
On Mon, Nov 14, 2011 at 10:50 AM, Andreas Neumann <a.neumann at carto.net>wrote:
> Hi Nathan and others,
> I like your new proposal, Nathan.
> At the dev-meeting in Zurich we also discussed marrying the attribute
> table with the forms. The forms would be in the same window as the table
> you could jump between form and table using tabs.
> It would have the advantage of fewer windows and we would add navigation
> buttons to the forms, like
> * jump to first record
> * last record
> * next record
> * previous record
> * indication of the total nr of records
> * button to change to edit mode
> * button for new record
> * button to filter records (using the query builder)
> * button to remove filter
> * button to highlight current and/or selected record(s)
> * later: also a button to export current selection to csv/xls/openoffice,
> etc.
> The filter and the add/delete function would work simultaneously on the
> tables and forms.
> The other things we want to add are master/detail forms for one to many
> relations and a tab for showing related forms or tables.
> The Autodesk Topobase product is a very good source of inspiration for
> such a combined table/forms approach. See
> http://images.autodesk.com/adsk/files/topobase_-_customizable_forms.bmpfor an example.
> Jürgen Fischer will be working for us to improve the forms/tables - so
> Nathan, maybe you could team up with Jürgen to improve the tables and
> forms. I would also be interested in discussing new approaches and ideas,
> but I cannot contribute from a programming point of view.
> Andreas
> On Mon, 14 Nov 2011 18:54:55 +1000, Nathan Woodrow wrote:
>> Hi all,
>> Today I was looking at some different ways to redesign
>> and optimize the attribute table UI and have come up with a design
>> that I think works well but would like to get some feedback first.
>> I have made two screenshots, showing the old and new dialog at the
>> same size and using the same Qt theme.
>> Just a plain comparison screenshot
>> : http://dl.dropbox.com/u/6170988/Plain.png [1]
>> Comparison screenshot with notes
>> : http://dl.dropbox.com/u/6170988/Noted.png [2]
>> The main things are:
>> * Make the min row height to 16. This removes the empty space
>> below
>> the text in the current UI and allows more rows to be shown with less
>> wasted space.
>> * Reduce some of the margins around the controls.
>> * Move the search stuff to the top in order to give search text
>> more
>> space and group the items better. All search options at the top.
>> * Replace Advanced search button with a hyperlink style button.
>> This is less distracting from a UI point of view IMO.
>> * Remove Search button as Enter on the keyboard does the same
>> thing.
>> Is a button really needed?
>> * Split buttons at bottom into two groups. Actions for current
>> selection and stuff that only works in edit mode e.g. adding new
>> column.
>> Over all you can show about 4 more rows depending on the theme.
>> Having the search at the top for me feels better as it is less
>> cramped then where it is now and makes more sense to click Show
>> Selected Only and seeing the results below.
>> Anyone have any thoughts about the design?
>> - Nathan
>> Links:
>> [1] http://dl.dropbox.com/u/6170988/Plain.png
>> [2] http://dl.dropbox.com/u/6170988/Noted.png
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111114/ef263013/attachment.html
