[Qgis-developer] More git troubles ...
    Anne Ghisla
    a.ghisla at gmail.com
    Tue Nov 15 05:15:52 EST 2011
On Mon, 14 Nov 2011 15:32:12 +0100
Andreas Neumann <a.neumann at carto.net> wrote:
>  so for now - until I find a better solution - I am git-ting on a
> remote server and rsync it to my machine within the employer's
> network.
>  Not a very nice solution, but at least it works ...
Just a side note: I wonder why it is so difficult to access
non-standard ports and services related to work activities.
Even if they are blocked by default, it should be easy to unblock them,
once the motivation is clear...
cheers,
Anne
>  the "socat" solution described at
>  http://sitaramc.github.com/tips/git-over-proxy.html did not work
>  unfortunately.
>  Thanks,
>  Andreas
>  On Mon, 14 Nov 2011 15:07:59 +0100, Andreas Neumann wrote:
> >> Something seems up with using the https:// version.
> > too bad.
> >> Try using git://github.com/qgis/Quantum-GIS.git [2] instead.  This
> >> works on my end
> > unfortunately the git protocol does not work on port 80/443 - it
> > requires port 22 which I do not have open. Also, we have a proxy ...
> > How I hate these proxy/firewall things ...
> > I found these ideas:
> > and see if it helps.
> > Andreas
http://gis.cri.fmach.it/ghisla/
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111115/a8e524d6/signature.bin
