[Qgis-developer] Projection widget improvement
Werner Macho werner.macho at gmail.com
Thu Nov 17 04:14:36 EST 2011
Hi
> For me, for example: I would want to set the focus to the 'find' button
> as soon as you try to type something into the find-text input.
> Now I always find myself typing a code and then hitting <enter> without
> result (because 'apply' apparently has focus: you really have to click
> the <find>  button.
> And why not make a general find: why must I choose between both
> Authority and Name/Id. There are not so much combinations: just search
> over al fields please! So we can remove the two dropdowns?
+1 for Richards suggestion .. I also always hit enter after entering
something in the search field .. and see the window disappear only to be
reopened again .. And if it would be possible to "just" search either it
is EPSG code or a string that would even make that search easier ..
regards
Werner
