[Qgis-developer] "official" qgis users?
Tim Sutton
lists at linfiniti.com
Thu Nov 17 09:44:56 EST 2011
Hi
On Thu, Nov 17, 2011 at 4:42 PM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> 8<-------------------------snip------------------
>>> The user map page needs to have a separate view made just for the
>>> wizard which excludes all the navigation stuff (maybe Alessandro can
>>> help with that?) so that the registration page fits more naturally
>>> into the wizard. We can use the same technique to let the user
>>> register with osgeo and do other things like show them news or
>>> whathave you.
>> which pages (URLs please) exactly are you planning to include in the wizard ?
> At the moment it only points to
> http://users.qgis.org/community-map/create_user_form.html
> And I would like to make it work only with user registration there
> before doing the other items on Paolo's wish list. So the idea would
> be to create new views / templates for the QGIS embedded registration
> that has no menus, page heading etc and a smaller map. The content
> should also be in a div with overflow set to scroll vertically so that
> the wizard page stays its normal size.
By the way if you are testing you need to reset
showWelcomeWizard
to 1 in ~/.config/QuantumGIS/QGIS.conf each time you run QGIS in order
to see the wizard. I guess it should be added to the help menu too...
Regards
Tim
> Thanks
> Regards
> Tim
>> Alessandro Pasotti
>> w3: www.itopen.it
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
Skype: timlinux
