[Qgis-developer] Why I'm not going to use hub.plugins.org for my
plugins
Pirmin Kalberer
pi_ml at sourcepole.com
Mon Nov 21 08:11:21 EST 2011
Hi Alessandro, Tim,
Am Montag, 21. November 2011, um 12.48:08 schrieb Tim Sutton:
> On Mon, Nov 21, 2011 at 1:41 PM, Alessandro Pasotti <apasotti at gmail.com>
wrote:
> >> There are hundreds of redmine plugins out there, probably there is one
> >> to let users delete their projects. I still wonder if it is a good
> >> idea for other reasons though - if I file a bug against your project
> >> and spent time and effort on working with your plugin I may not want
> >> to see my work on your redmine project dissapear overnight because you
> >> became bored with it. Better in my mind that an admin delete it after
> >> giving it some consideration.
> > In that case (which it's a corner case) you'd probably have the code
> > in GIT anyway or at least the plugin installed on your disk and you
> > could still create a new project.
> Sorry but I was referring to the bug tracking history relating to the
> plugin, not the code (I realise I have the code already). The history
> of what issues people report against the plugin and what resolutions
> took place and why is useful information that should persist should
> e.g. a new maintainer take over the plugin because the former one got
> bored.
> It looks like the reason you can change your project to a subproject
> of QGIS Desktop is because you are listed as a manager of that
> project. So it seems that the rule is : you cant make your project (A)
> a subproject of (B) unless you are at least a manager of (B). This
> probably makes good sense because otherwise we give everyone perfect
> freedom but also have potential anarchy e.g. users just inserting
> their project as a child of yours without consulting you.
> So I think the workflow should be that when a user wants to create a
> new project, it should always go under plugins, and if that is the
> wrong place they should file a ticket.
As soon as Mathias some hours left (should be next week), he will write a
plugin for customizing Redmine to QGIS' needs. The most important things I
currently see:
-Don't show members of project, if more than 50 (#3983)
-Make "User plugins" the default parent project for new projects (#3956,
#4545)
-Hide Repository link on Overview page (currently implemented as patch)
Regards
Pirmin
Pirmin Kalberer
Sourcepole - Linux & Open Source Solutions
http://www.sourcepole.com
