[Qgis-developer] Why is scrolling in the attribute table so slow?
Jürgen E. Fischer jef at norbit.de
Thu Nov 24 06:13:36 EST 2011
Hi Nathan,
On Thu, 24. Nov 2011 at 21:04:48 +1000, Nathan Woodrow wrote:
> If your using PostGIS there seems to be some open/close connection bug.  If
> you look at the debug log for QGIS while you click, scroll or do anything in
> a PostGIS backed datasource you will see a lot of database requests.
The attribute table only initially loads the ids of the features and lazy loads
the actual data when it's needed using featureAtId.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
