[Qgis-developer] redmine reopen
Alexander Bruy alexander.bruy at gmail.com
Fri Nov 25 04:07:42 EST 2011
Hi Werner,
I already submit ticket for this issue. See http://hub.qgis.org/issues/3992
2011/11/25 Werner Macho <werner.macho at gmail.com>:
> Hi!
> I stumbled across the issue that a ticket on redmine - once closed - cannot
> be reopened ..
> Is that meant that way? Is there a problem? Can somebody look if it should
> work?
> I only found one webpage [1] discussing the problem but i am still not sure
> if it should work somehow or not ..
> thanks a lot
> regards
> Werner
> [1] http://www.redmine.org/boards/2/topics/5125
> Qgis-developer mailing list
Alexander Bruy
