[Qgis-developer] redmine reopen
Werner Macho werner.macho at gmail.com
Fri Nov 25 02:40:07 EST 2011
Hi!
I stumbled across the issue that a ticket on redmine - once closed -
cannot be reopened ..
Is that meant that way? Is there a problem? Can somebody look if it
should work?
I only found one webpage [1] discussing the problem but i am still not
sure if it should work somehow or not ..
thanks a lot
regards
Werner
[1] http://www.redmine.org/boards/2/topics/5125
