[Qgis-user] Re: [Qgis-developer] Critical problems with 1.7.2
from ubuntu binaries
Agustin Lobo
alobolistas at gmail.com
Tue Nov 29 04:16:10 EST 2011
Just solved the same problem on a machine running ubuntu 11.04 by
reinstalling all components and
reproduced the problem by installing on another machine with ubuntu
10.04 . Running qgis from the command line I get:
alobo at delia:~$ qgis
Warning: loading of qgis translation failed [/usr/share/qgis/i18n//qgis_en_US]
Warning: loading of qt translation failed [/usr/share/qt4/translations/qt_en_US]
Warning: Couldn't load Python support library: Cannot load library
/lib/qgispython: (/lib/libqgispython.so: cannot open shared object
file: No such file or directory)
I assume the problem will be solved by reinstalling all components on
this computer as well, but I can hold on for a while in case
anyone is interested on me running a test to identify the component
actually producing the problem.
I remind that I'm installing from ubuntugis-unstable in all cases.
Agus
2011/11/29 Niccolo Rigacci <niccolo at rigacci.org>:
> On Tue, Nov 29, 2011 at 07:12:24AM +0100, Agustin Lobo wrote:
>> After updating to 1.7.2 in ubuntu 10.4 LTS using the
>> ubuntugis-unstable repo, the CRS cannot be set:
>> "Could not open CRS database /resources/srs.db<br>Error(14): unable to
>> open database file!
> I got a similar problem with a self-make Debian package: it was a
> package not correctly updated (strange enough it was
> qgis-plugin-grass, if I remember well).
> I removed the stale old package and reinstalled the new one to
> fix.
> Check what you have with: dpkg --list | grep qgis
> Niccolo Rigacci
> Firenze - Italy
> Tel. ufficio: 055-0118525
> Qgis-user mailing list
