[Qgis-user] Re: [Qgis-developer] Critical problems with 1.7.2
from ubuntu binaries
Noli Sicad
nsicad at gmail.com
Tue Nov 29 05:09:20 EST 2011
> reproduced the problem by installing on another machine with ubuntu
> 10.04 . Running qgis from the command line I get:
> alobo at delia:~$ qgis
> Warning: loading of qgis translation failed
> [/usr/share/qgis/i18n//qgis_en_US]
> Warning: loading of qt translation failed
> [/usr/share/qt4/translations/qt_en_US]
> Warning: Couldn't load Python support library: Cannot load library
> /lib/qgispython: (/lib/libqgispython.so: cannot open shared object
> file: No such file or directory)
In ubuntu 10.04 Lucid, you have to install
- python-qgis 1.7.2~Lucid1
- python-qgis-common 1.7.2-1~Lucid1
If you upgrade from other version (e.g. 1.7.0), you have to remove
first the old version then install 1.7.2.
Noli
