[Qgis-user] Re: [Qgis-developer] Critical problems with 1.7.2 from ubuntu binaries
Agustin Lobo alobolistas at gmail.com
Tue Nov 29 06:43:28 EST 2011
I do have
> - python-qgis 1.7.2~Lucid1
> - python-qgis-common 1.7.2-1~Lucid1
but have some other  <1.7.2 leftovers:
alobo at delia:~$ dpkg --list | grep qgis
rc  libqgis1.4.0                                  1.4.0-2~lucid8
                           Quantum GIS - shared libraries
rc  libqgis1.5.0                                  1.5.0-2~lucid2
rc  libqgis1.6.0                                  1.6.0-4~lucid1
rc  libqgis1.7.0                                  1.7.0~lucid1
ii  libqgis1.7.1                                  1.7.1-1~lucid1
ii  libqgis1.7.2                                  1.7.2-1~lucid1
ii  python-qgis                                   1.7.2-1~lucid1
                           Python bindings to Quantum GIS
ii  python-qgis-common                            1.7.2-1~lucid1
                           Python bindings to Quantum GIS -
architectur
ii  qgis                                          1.7.2-1~lucid1
                           Geographic Information System (GIS)
ii  qgis-api-doc                                  1.7.2-1~lucid1
                           Quantum GIS API documentation
ii  qgis-common                                   1.7.2-1~lucid1
                           Quantum GIS - architecture-independent data
ii  qgis-mapserver                                1.7.2-1~lucid1
                           Quantum GIS mapserver
ii  qgis-plugin-grass                             1.7.2-1~lucid1
                           GRASS plugin for Quantum GIS
ii  qgis-plugin-grass-common                      1.7.2-1~lucid1
                           GRASS plugin for Quantum GIS -
architecture-
ii  qgis-providers                                1.7.2-1~lucid1
                           collection of data providers to Quantum GIS
ii  qgis-providers-common                         1.7.2-1~lucid1
rc  qgis-sqlanywhere1.7.0                         1.7.0~lucid1
                           Quantum GIS sql anywhere plugin and
provider
ii  qgis-sqlanywhere1.7.1                         1.7.1-1~lucid1
provider
and the problem is solved by uninstalling just:
(even not having to install qgis-sqlanywhere1.7.1)
Anything else that would be more hygienic to remove?
Thanks,
Agus
2011/11/29 Noli Sicad <nsicad at gmail.com>:
>> reproduced the problem by installing on another machine with ubuntu
>> 10.04 . Running qgis from the command line I get:
>> alobo at delia:~$ qgis
>> Warning: loading of qgis translation failed
>> [/usr/share/qgis/i18n//qgis_en_US]
>> Warning: loading of qt translation failed
>> [/usr/share/qt4/translations/qt_en_US]
>> Warning: Couldn't load Python support library: Cannot load library
>> /lib/qgispython: (/lib/libqgispython.so: cannot open shared object
>> file: No such file or directory)
> In ubuntu 10.04 Lucid, you have to install
> If you upgrade from other version (e.g. 1.7.0), you have to remove
> first the old version then install 1.7.2.
> Noli
> Qgis-developer mailing list
