[Qgis-developer] Fwd: [Quantum GIS Desktop - Bug #4550]
Improvements to projection widget
Paolo Cavallini
cavallini at faunalia.it
Wed Nov 30 02:11:07 EST 2011
Good job Richard, I appreciate it.
A question: could someone please apply the same widget everywhere?
A few dialogs (e.g. for SpatiaLite) use a different interface, and this
inconsistent behaviour is disturbing.
Thanks a lot.
All the best.
-------- Messaggio originale --------
Oggetto: [Quantum GIS Desktop - Bug #4550] Improvements to projection
widget
Data: Tue, 22 Nov 2011 06:41:52 -0800
Mittente: redmine at qgis.org
A: undisclosed-recipients:;
Issue #4550 has been updated by Richard Duivenvoorde.
This has always been the case I think. There can actually (depending on
the size of the dialog) be 3 or 4 lines of proj-parameters. But we also
want to minimize the size of the dialog. Besides that, there is actually
nothing you can do with those parameters (besides look at them...).
So: given we want to miminize the dialog: do you still want it to be bigger?
|(by the way: the changes is already in master, so please have a look and try).|
Bug #4550: Improvements to projection widget
<http://hub.qgis.org/issues/4550>
* Author: Paolo Cavallini
* Status: New
* Priority: Normal
* Assigned to: Richard Duivenvoorde
* Category: GUI
* Target version:
* Must fix:
* Platform:
* Platform version:
* Status info:
* Resolution:
* Patch supplied: No
I think the projection widget should be improved, by
* having the search filtering the projections rather than moving to
the next matching (see e.g. in the plugin list)
* it would be good to have the search working in both fields (people
often overlook the search field selector)
* the internal projection ID could be hidden (I do not see any use
of it for the user)
* set the focus to the 'find' button as soon as you try to type
something into the find-text input.
Now the user often type a code and then hit <enter> without
result, because 'apply' apparently has focus: you really have to
click the <find> button
* better make a general find: just search over al fields, so we can
remove the two dropdowns
Single tickets might be opened, but I think once we start cleaning up
the interface it is a simple matter to do all.
You have received this notification because you have either subscribed
to it, or are involved in it.
To change your notification preferences, please click here:
http://hub.qgis.org/my/account
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111130/9dbd01b0/attachment.html
