[Qgis-developer] How should work the placement "over" on adv-label
Andrea Peri aperi2007 at gmail.com
Mon Oct 3 16:38:54 EDT 2011
I have a situation of polygon like this:
  |         A      |
  |  |  B     |    |
Where the poly A has a hole and the poly-B fill exactly the hole of poly-A
I need to have a labeling like this:
  |       value1   |
  |  | value2 |    |
I try with the label-advanced plugin and use the option Placement "Over".
But it produce instead this situation:
  |  | value1 |    |
  |  | value2 |    |
I don't know if this is a wanted result or not for the "over" placement.
But I guess this is not the better solution , because don't allow to
understand what is the label
of PolyA and the label of PolyB.
Thx,
Andrea.
Andrea Peri
qwerty àèìòù
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111003/b54d918b/attachment.html
