[Qgis-developer] Installed Qgis on Ubuntu - what do I do next?
Christopher Stark
christopherstark at gmx.de
Sat Oct 15 12:43:07 EDT 2011
Hi Marco,
thank you this works. Is there a more comfortable way of displaying a
map - with a web-frontend-page or do I have to type in every command
manually like this
e.g.:
http://localhost/cgi-bin/world/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&
REQUEST=GetMap&BBOX=-36.215710,6.817432,-9.700450,58.551008&
CRS=EPSG:4326&WIDTH=1077&HEIGHT=552&LAYERS=Continent,Country,Cities&
STYLES=,,&FORMAT=image/jpeg&DPI=96
It seems to be very complicated and time consuming to work like this (as
I'm a big GUI-fan)
Best regards
Christopher
Am 15.10.2011 16:25, schrieb Marco Hugentobler:
> Hi Christopher
> This error message shows that it works (you just did not make a valid WMS
> request). To publish your project, you need to give the file path to the .qgs
> project in the url and the wms request parameters.
> http://localhost/cgi-bin/qgis_mapserv.fcgi?map=/home/me/myproject.qgs&
> is the WMS url
> bin/qgis_mapserv.fcgi?map=/home/me/myproject.qgs&SERVICE=WMS&REQUEST=GetCapabilities
> should return an xml document with the available layer, styles, crs, etc.
> Regards,
> Marco
> Am Samstag, 15. Oktober 2011, 12.23:56 schrieb Christopher Stark:
>> Hi,
>> thank you. I did all this but now I get this error message:
>> This XML file does not appear to have any style information associated
>> with it. The document tree is shown below.
>> <ServiceExceptionReport version="1.3.0"><ServiceException
>> code="ServiceNotSpecified">Service not specified. The SERVICE parameter
>> is mandatory</ServiceException></ServiceExceptionReport>
>> Questions below:
>> Am 14.10.2011 21:50, schrieb Giovanni Manghi:
>>>> What should I do as first steps after installing?
>>> if working correctly, the address
>>> should return
>>> code="OperationNotSupported">Please check the value of the REQUEST
>>> parameter</ServiceException></ServiceExceptionReport>
>>> Then just create a project in QGIS (use absolute paths) and in the
>>> project properties configure the parameters in the "WMS server" tab.
>> which paramenters are important here? What does absolute paths mean in
>> this regard
>>> Create a folder in
>>> /usr/lib/cgi-bin/
>>> and copy into it your QGIS project and a copy of qgis_mapserv.fcgi
>>> your server address will be
>>> http://localhost/cgi-bin/myprojectfolder/qgis_mapserv.fcgi
>>> cheers
>>> -- Giovanni --
>> Best regards
>> Christopher
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111015/550501e4/attachment.html
