[Qgis-developer] Installed Qgis on Ubuntu - what do I do next?
Noli Sicad
nsicad at gmail.com
Sat Oct 15 22:40:00 EDT 2011
> The most common web client being Openlayers, this will require work on
> your part, mainly a few lines of javascript in a web page. You might be
> able to use it directly in Geocommons or in Mapfish (also takes setup).
This is how Tim used it for OpenLayers client (below).
Very few documentation how to actually use in OpenLayers and WMS.
Noli
<script type="text/javascript">
var map, layer;
function init(){
var MapOptions = {
projection: new OpenLayers.Projection("EPSG:32633"),
units: "m",
masxScale: 19567.879237500,
//maxScale:1000,
//minScale:17000000,
numZoomLevels: 10,
resolutions: [19567.8792375, 9783.93961875,
4891.969809375, 2445.9849046875, 1222.99245234375, 611.496226171875,
305.7481130859375, 152.87405654296876, 76.43702827148438,
38.21851413574219],
maxExtent: new
OpenLayers.Bounds(-918304.23600184,6418410.00099619,1957227.50491800,7976533.94886646),
fractionalZoom: false,
transitionEffect:"resize",
map = new OpenLayers.Map( 'map', MapOptions );
layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
"http://maps.linfiniti.com/cgi-bin/tilecache.cgi",
{layers: 'utno-test'} );
map.addLayer(layer);
map.zoomToMaxExtent();
</script>
</head>
<body onload="init()">
<div id="map" class="map"></div>
</body>
