[Qgis-developer] Map vs. Line line labelling orientation
Martin Dobias
wonder.sk at gmail.com
Sat Oct 22 12:01:26 EDT 2011
On Sat, Oct 22, 2011 at 12:51 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Sat, Oct 22, 2011 at 12:45:33PM -0300, Martin Dobias wrote:
>> the intended semantics is as follows:
>> - with the "map" orientation the "above line" and others should work
>> as one would expect: the label should appear above the line
> What would you expect when the line is a vertical line ?
I would expect that with "above line" placement a line going up gets
the label on the left side. Contrary, a line going down should have
the label on the right side.
Martin
